Nitrous Oxide System
RE: Nitrous Oxide System
You have a C&L intake, so you must have a tune. Chances are you're running some pretty advance timing. If you were on the stock tune, then you'd be OK with a 75 shot maximum. Otherwise, you're risking detonation. Best to get it tune for safety.
An RPM switch will either come with the kit (NOS includes one) or cost $150 or so. You just can't run a safe system without one.
Other safety components are pretty cheap. A blow down tube is about $20. The bottle adapter was maybe $10. My fuel pressure safety switch (30 psi Edlebrock) was $20, but I needed a $15 adapter.
I have the zex kit and it seems to work good. You set it up so it will only activate at full throttle. If you plan to shoot a 75 shot, I would get a tune. For as cheap as the kit is and as cheap as dyno time is, get the thing tuned. I think the stock fuel pump can handle 150 shot. Or i should say i know it can. You will love the 75 shot so much, that you will want more. So i suggest get a tune for 75 and for 125 or 150. You wont be disappointed. jt
bradleyb
11-27-2015 07:50 PM
breaking
10-02-2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
