New Ford Racing Hot Rod CAM M-6550-3V
#32
RE: New Ford Racing Hot Rod CAM M-6550-3V
I'm looking to compliment it with a Whipple 500HP SC in the Spring.
#33
ORIGINAL: stangNV
y not just stay with factory springs? if you get aftermarket ones youll have to change them every 20 to 25000 miles...my uncle is using factory springs with 700 rwhp
#35
variable cam timing.....and you can run some cams without new springs there is not doubt about it. Comp cams has 4 versions of there NSR that will allow for this. But all other sets from Comp and all from Blow by Racing suggest that you replace the springs. I looked at Crower selection too and with teh lifts they advertise you would need to replace the springs will those too.
You can always get a custom regrind that would allow you to keep the stock springs but the "no springs" cams are fairly new and provide the lowest of gains out of all the different version out there.
Anyone running over 6500 RPMS on a fairly consistent basis with new cams will want new springs
#37
#39
www.americanmuscle.com
Get an SCT with a cold-air intake or rear gear. Both are awesome deals.
http://www.americanmuscle.com/05-07-...r-intakes.html
or
http://www.americanmuscle.com/mustan...kits-0510.html
Get the 4.10's for the 'holy jeebus' effect.
#40
Yep,
or
or
thanks. from what iv herd i may go with the sct and cold air intake. i have a guy makin me a good deal on a bullydog speed chip and bigger injectors, screen, gauges, and instalment. for 200. worth it?
xbmx89
Texas Regional Chapter
11-10-2015 10:43 PM
squishbang
Suspension
11-02-2015 03:42 PM
