anybody with tips for measuring and marking centerline for shaker hood?
Like the title says. Anybody WHO HAS ACTUALLY DONE THIS please give me a detailed description on how you measured for, and physically marked the centerline of the hood.
I assume you can split the differencebetween the windshield "pee-ers" at the rear.
I also assume that the ridge in the middle of the hood is exact center. If so, what is a good way of marking this line?
I appreciate your help, tips, or moral support.
RE: anybody with tips for measuring and marking centerline for shaker hood?
See Taco bills How to guide section.+
I know the search function sucks so here is a link.
https://mustangforums.com/m_3111818/tm.htm
I put some tape down the center so that I could see the laser level that I had set up. Then I just measures the laser line back and fourth until it was even on top and bottom. Took about 15 minutes total.
ORIGINAL: Boozshey
Move it forward more then. Mine might have sat a little higher than the one you bought also. But it was just a $5.00 one at Harbor Freight that I used.
If someone could send you the roush templete used for the intsll of hood scoop that would be great....it would be perfect for this type of work...unfortunately I threw mine away two yrs ago...
ORIGINAL: ybnormal
David
ORIGINAL: TPony
I used the Ford logo in the windshield glass at the bottom to center
the roush hoodscoop template. And the squirter nozzles.
autoedit
09-27-2015 06:37 PM
