N2O On Barricade
#22
RE: NO2 On Barricade
Ooops, sorry that was just bad grammar. I was refering to the Zex window switch as a "cool unit". You can dial in what rpm the nitrous turns on and what rpm it turns off. The real handy feature is you can also program it to start spraying in whatever gear you want, so if your traction limited,you can skip spraying in first or second.
#23
you need a blow-down tube to run at the track.
150 is as high as i'd go. you need bigger injectors, autolite HT0's, and a really good tune. talk to brent at brenspeed, they run a 150 shot on their shop car.
