Hot Rod Cams Installed
Cams came in on Thursday and I installed them yesterday. The video has before and after shots. I have driven my car twice and everyone keeps stopping me and asking, What you got in that thing? I definitely need to get a hold of Doug @ Bama and get that tune he put together, I emailed him but if anyone has any info on that specific tune please chime in.
http://s283.photobucket.com/albums/k...HotRodCams.flv
Thanks.
Thanks.
RE: Hot Rod Cams Installed
ORIGINAL: Dragon Stang
That sounds wild Dude! Sweet!. What did it take to put them in? Any issues to be aware of? How much is involved?
a timing mark on the crank damper and that it should be in the 1 o'clock position, only problem is mine did not have the reference mark, so if you do the install you need to make sure the
# 1 and # 5 cylinders are coming up on the exhaust stroke. The reason for this is I believe the cams are at a point of the least tension. I only took three of the cam followers off the left side and had no problem with removal and install, but on the right side I thought I had it on the exhaust stroke but when I started taking the cam bearing caps off they began to bind so I tighten them back and removed all of the followers. It took longer but was worth the extra time.
ORIGINAL: whtcanbrwnd04u
How much did it set you back? Feel any difference? Thanks.
Tools- $238
Parts- $80(besides the $800 cams)
Time- 5 1/2 hours
Other than the car shaking..yes lost some bottom end, but if you are thinking of doing these cams just plan on a tune. I need to get it on the dyno or get a tune from Bama to make
a far assessment. Right now it just seems to be running rich.
