Cluster gage Questions?
I have a 2005 mustang GT. My coolant gage has quit working properly.
I only have four different gages, such as tack, speedo,fuel level, and coolant.
Now here is my question. Can i put a six gage cluster in and all the gages work or will I have to change something else to make it work, or will it not work?
RE: Cluster gage Questions?
If you have the blank info buttons on the center console take a small screw driver and pry it out and if there is wiring attached to the back of it then yes the my color 6 gauge cluster with info center will work. You will also have to get the info center buttons as well. Then you will have to go to the dealer and have the as built flashed to the car with the correct mileage.
cheers
cheers
Matt's 95 Stang
10-05-2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
