hot rod cams
RE: hot rod cams
ORIGINAL: Mishri
thats a pretty cheap cam install price.. very surprising.. a lot of people were saying most shops charge around $1000
RE: hot rod cams
ORIGINAL: zkiller
for what? sound?
i hear these cams are supposed to be really good?
Brenspeeds/comp cams NSR have had much better results in the way of power gains. They dont have near as much sound though
RE: hot rod cams
Didnt Doug say he was able to get 17 out of his car that he developed the tune through? And, 303 to the wheels is what a lot of guys push out with justfull exhaust/intake... with higher torque numbers sometimes...
RE: hot rod cams
ORIGINAL: tonkpils555666sas
Just a difference in what you want out of your car maybe. But i still want to see other results from the FRPP cams from others before i say they are a good or bad mod.
RE: hot rod cams
17 HP gain is what I had been told as an average without the ported heads. With ported heads I was told to expect closer to the 50 mark. Was trying to find the email where I was told that, but regardless seems about par.
Again, for me... I am from the old days when I could sit and just enjoy the sound of a good cam. So for me, the sound was worth a lot. I will tell you guys this... this lope is enough that the whole car visibly rocks some at stop lights and at very low speeds through our neighborhood rear house entry alleys, it is difficult to maintain at almost an idle in 1st - wants to buck some.
RE: hot rod cams
I just want to see more results... 50 rwhp out of hot rods and port/polished heads seems a bit off par based on what I have seen so far. Do you know is jmoose ever posted his results?
RE: hot rod cams
IMO I would never pay for 750 bucks for 17 rwhp, thats not even including the install. I'm going to the shop today to get my cams install (comp cam VSR stage 3 blower cams), and if I don't see AT LEAST 30 rwhp then I'm going to be pissed, because thats what i've been told I'll get by comp cam and the guy thats putting them in. I know there wont be anything I can do about it so I probably just go burn my tires off. For what I'm paying for parts and labor, if I only get 30 rwhp, I'm paying $66.66 for each rwhp. Petty expensive when you compare it to a S/Cer.
