mgw shifter
RE: mgw shifter
i thought it might be road noise,it is alittle bit louder then stock,but this noise is metal to metal noise,also the shifter came with blue plastic in the piece that arm goes trough from the shift arm should put 2 stock ones in?
RE: mgw shifter
I just installed the new Hurst billet model, and no problems. It uses the two stock bushings in the shifter arm.....
The only other thing I can think of is the rear mount to those small studs....as mentioned in an above post.
thanks for everybodys help, i found what was making the noise. Since i bought the car new in the spring i thought there was something wrong in the drive line.the transmission was not centered right, i backed off the 4 bolts off that hold the crossmember and the transmission moved to the left 1/4 inch now everything is fine the bolt that holds the arm to the transmission was hitting the body very slightly.Feels great now. thanks once again this forum rocks
junior04
09-28-2015 10:53 AM
