Severe rear end problem--- Headed to dealership
I just use the factory synthetic gear oil and friction modifier.
I only use a half bottle of friction modifier though.
I was going to tell you it was the spider gears but looks like you already found it.
Would be an excellent opportunity to upgrade to an Eaton Detroit TrueTrac.
Stonger, No clutches to wear, more aggressive biasing, but still allows smooth cornering unlike a locker.
With the TrueTrac you can skip the friction modifier.
so please dont hang the noob out to dry on this one but what would the Eaton Detroit TrueTrac do and what componants would it work with i guess the question would be what are the benifits to buying it i already have 4.10 gears at my house just kinda curious as to the benifits the Eaton has
thanks
thanks
You can go to Eaton's website and read. The main difference between the two is durability IMO. The same LSD actions of the T-LOK are in the True Trac, but the true trac is a gear driven unit instead of a clutch pack unit, giving better durability. I have seen several (including mine) at the track start to loose their ability to modulate power back and forth between the rear wheels. For someone who is going to go to the track or run with some type of forced induction, I would upgrade to a better unit when replacing gears. There will be no extra labor involved and a new unit costs around $425.
Here's a link:
http://store.summitracing.com/partde...5&autoview=sku
Here's a link:
http://www.buyfordracing.com/shop/pr...=543cPath=3_37
I was thinking this unit solely because he has one just sitting as his house new in a box. He said he would sell it to me for 100 bucks. It must be slightly stronger then stock
That's a good buy for sure. I do not know the compatability but your mechanic should. If I were upgrading and were trying to save some cash I would get it. The difference between your and the Cobra's is the clutch pack.
The FRPP trac-lock diff. is basically an F-series 31 spline which has a stronger S spring (puts the tension on the drive gears/clutch packs). From what I know, they also have the newer style cf clutches.
But, a $100.00 is a good deal!
If money is there...........do the Tru-Trac
Casey
Casey
inyadreems
08-21-2015 09:10 AM
91StangOwner
08-20-2015 11:34 PM
Black_GT_02
08-20-2015 01:26 PM
