A while back I put a smaller pulley on my Saleen blower and had 9.5 lbs of boost. That lasted about a week. Ever since I can only get about 8 lbs. Anyone know why?
3.4 pulley. My idler pulley makes a whining noise.
If all your pulleys are the stock ones, you might benefit from a 100mm idler pulley or 90mm tensioner pulley. I'm not sure if you can run either of these with the saleen belt routing though.
i assume your running a 6 rib belt setup. i am betting belt slippage to...get the 8 rib kit and I would bet problem be solved with new belt. how many miles is on that belt at this point
