Last edit by: IB Advertising
Browse all: Ford Mustang Powertrain Guides
- Ford Mustang V6 2005-2014: How to Flush Radiator
Step by step instructions for do-it-yourself repairs.
Drain & Flush Cooling System
Anybody done a drain & flush of the cooling system? Does the 4.6 block have block drain plugs? A local shop I trust charges $109 (includes coolant). I wonder if it's worth doing myself or have them do it. They install Zerex G-50 (gold) which meets the Ford spec. Thoughts?
The block does not have a drain provision. Only the radiator does. $109 is about $20 more than I charge for a coolant flush.
Doing it yourself is always cheaper, no matter what the topic. Having someone else do the work has its benefits too. No mess in your driveway/garage. Proper disposal of old coolant. Etc.
cooling refill
I have always started at about 20000 miles, I drain the radiator and refill will a 50/50 mix coolant and distilled water, I do this every other oil change, My 1992 T-Bird had over 200000 miles when I sold it and no cooling system problems.
Use a shop vac and now you are talking. It will suck the whole
cooling system dry. Make sure you have an air inlet as well as an air
outlet to the vacuum or you will pull quite a vasuum on the cooling
system. Bad. Could collapse the radiator.
Used to winterize pool plumbing with a shop vac.
After about 30 minutes of sucking, the pipes were dry.
Cooling system suck
Its OK to do it that way but you wont get 100% of the coolant out.
bradleyb
11-27-2015 07:50 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
