TCI 5r55s 1,200 hp ? - MustangForums.com
Old 09-23-2008, 10:40 PM
MexGT
Default TCI 5r55s 1,200 hp ?
As topic says, TCI rates their 5R55s up to 1,200 hp ?
http://www.jegs.com/i/TCI/890/571000/10002/-1
Opinions?
MexGT is offline
Old 09-24-2008, 12:06 AM
SirKnightTG
SirKnightTG's Avatar
If so damn I want one. LOL.
Like the StreetFighter units, these are equipped with our 100% tested, Manual/Automatic valve body. That means that most units allow you to manually shift the vehicle into each gear change or, by placing it in the drive position, remain fully automatic. In either mode, you get a racetrack shift that bangs through the gears and shaves time off your ET's. When you use the manual gear selection feature, the Super StreetFighter upshifts and downshifts right when you move the lever, with no lag or governor override.
FTW!
I manually shift mine quite often and I can tell that sometimes it doesn't like it when I do it. A new 5R55S that's made to shift manually or use in D is a WIN for me.
I'm also sort of surprised about the price. I would have expected it to cost a lot more.
What I need now are some customer reviews. *looks at Mex*
SirKnightTG is offline
Old 09-24-2008, 06:45 AM
zkiller
zkiller's Avatar
I am calling the BS flag on this tranny. Aint gonna happen, no way, no how.
Level 10 had their 5R55S trans out in June of 2006. Why does it take TCI so long to bring this product to market?
zkiller is offline
Old 09-24-2008, 07:42 AM
MexGT
Everytime TCI talks about their 5r55s they come out with a different rwhp rating lol
MexGT is offline
Old 09-24-2008, 12:12 PM
ybnormal
ybnormal's Avatar
I thought one of the problems with our transmissions was in the size/machineing of a shaft inside, I remember reading about some body in cal. that made a beefed up version for the 5r55 but I never heard any more about it. Are the clutches the weak spot? What HP are you guys running that causes problems with these autos?
Description said 1200 hp then it reads NA up to 600 hp what gives?
The Flag must wave here!!!!
ybnormal is offline
Old 09-24-2008, 04:08 PM
rshamekh
rshamekh's Avatar
It doesn't mention anything about a better input shaft.
It also says it's intended for NA vehicles.
I'd rather get my transmission built at Larry's.
rshamekh is offline
Old 09-25-2008, 09:15 AM
08StangGT_CS
Must learn more.... I'm planning mine will last me many thousand miles before it needs replacing.
08StangGT_CS is offline
aznpersuasion
07-11-2018 07:40 PM
poke68
12-15-2015 07:25 PM
nmra1965
Other Professional Racing
09-26-2015 11:46 AM
Sminemann
09-17-2015 10:24 AM
robjh22
Suspension
09-08-2015 01:47 PM
Quick Reply: TCI 5r55s 1,200 hp ?
Featured Sponsors
