Fan on our cars
Old 09-26-2008, 08:28 PM
onebad95
Default Fan on our cars
Has anyone figured out a way to wire up a switch to turn the fan on while it is shut off. For example, to cool down at the track ?
onebad95 is offline
Old 09-26-2008, 08:30 PM
Sxynerd
Sxynerd's Avatar
M u stang World.com has a write up.
Sxynerd is offline
Old 09-27-2008, 09:12 AM
Sxynerd
Sxynerd's Avatar
You can ground pin 85 on the cooling fan relay to a switch inside the car.
Sxynerd is offline
Old 09-27-2008, 09:14 AM
157dB
Cut & Paste Expert
157dB's Avatar
If I have to search M U Stang W O Rld. Co m to find the write-up,
might as well search the forum we are in now for the answer.
MustangForums - Fan Switch Post 07-09-08
157dB is offline
157dB
Cut & Paste Expert
157dB's Avatar
Which cooling fan relay?
There are two cooling fan relays.
One for low speed and one for high speed.
And they are not inside the car.
They are under the hood in the BEC.
And the pin numbering changed at one point
between the 05 stangs and the 08 stangs.
157dB is offline
Old 09-27-2008, 02:46 PM
Sxynerd
Sxynerd's Avatar
It depends on which one you want to use... If you have a battery that can support it then do the high speed if you want.
I have mine on the Low speed, Although I have a Deep cycle blue top optima, also incorporated with my electric water pump I don't even need the car running to cool my car. i didn't find necessary for me use the high speed.
Sxynerd is offline
Old 09-27-2008, 03:12 PM
157dB
Cut & Paste Expert
157dB's Avatar
Deep cycle as the starting battery?
Wont that prematurally kill it from the high starting amperage draw.
Deep cucle only means it can be slowly deep cycled without damage.
I would think using it as a starting battery would eventually warp
the internal plates and kill a cell or two.
157dB is offline
chain
08-17-2015 08:52 AM
jdphillips73
08-16-2015 04:34 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
HIS S-197
08-10-2015 05:47 PM
Quick Reply: Fan on our cars
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
