wider tire?
157 - there was nothing wrong with your approach - it would apply quite accurately for something like a free-rolling steel railroad wheel. IOW, it's an omission of something not generally obvious rather than an "error".
What's easy for most people to miss is that there is a correction for tire tread circumferential compression as it passes through the contact patch zone. The amount of this compression lies somewhere between the difference between circumference calcs based on the unloaded and loaded radii, and most folks don't have any tire tech references handy to give them a number to put on this even if they recognize that the effect exists.
Norm
Norm
Last edited by Norm Peterson; 11-28-2008 at 09:42 AM. Reason: I type slow and had to add a post reference
Norm
Norm
I thought of this when replying but didnt want to get too technical.
Like air pressure effecting the REVS/MILE because of the contact patch
situation with air filled rubber tires and not steel train wheels or wagon
wheels with zero slippage so as to not have to factor that variable into
the equasion also. I measured my BFG 255/45-18 KDW2s muonted on
18x8.5" rims and they differed from my numbers but were close to the
235/55-17s I removed and the 215/65-16s that were OEM.
jwog666
12-27-2021 08:09 PM
KingRando
10-02-2015 08:06 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
