fan on off switch?
fan on off switch?
does anyone know how to set a stang up with a switch so when i am racing i can keep the rad. fan on to help cool off the engine.
can a switch be put in line with the elec. wiring to bypass turning the fan off when it hits a set temp, so the fan will stay on if i want at the track and then put it back to work like stock when away from the track?
you probably can do a switch if you really
want to, but another possibility is to use
your handheld tuner (if you have one) to
set the turn on temps low, so the fans will
pretty much stay on continuously anyhow
if you don't have a tuner or don't want to go that
route, pm 157db, he is the guru in these matters
and will steer you in the right direction
09-25-2015 09:06 AM
