how do you throttlestop a FBW?!?!?!
i only want to go slower so i can complete in the 12 sec bracket...i am not fast enough in the 11 sec bracket to compete. So I came up with my own solution to the issue and will test it out tomorrow night at the track. here is a pic of it...see if you all have a clue what i did
you put a metal bracket behind the petal. nice but i would probably break it. I would weigh down your trunk. 200lbs should do it.
and 3 67lbs chicks.. must be 8 years old not cool
2 100lb thats better.
I still would be afraid of damaging something with the throttle stop method.
If the pro racers are running too fast in any type of racing, officals make them add weight.
I don't think that metal piece will work, and if it does, it will slow you down too much. Our cars, with drive by wire, recognize WOT after a certain pedal position. I'm sure you know, once the car is in WOT, all fuel mapping, shifting for autos, etc changes. The last 1/4" or so of pedal travel does not matter, once you pass a certain point, you will be in "WOT mode".
If the thing does work and keep you out of WOT, you will be out of WOT for the whole run and it will slow you down ALOT more than .2 sec.
I agree with adding weight. .2 sec in the quarter is so minute a time diference, it's not likely something you can precisely control with your foot. In fact .2 -.3 sec has alot more to do with launch, tire pressure, ambient temps and actual weight. For example, my car improved .51 sec just by running on a day that was 40 degrees cooler!
