I just Fu(ked my tune up.
So I got someone that wanted to buy my old SCT handheld and I wanted to make sure that it was unlocked instead of taking my tuners word for it. So I went down to my car and plugged the SCT into my car and checked the tune status. It read "Vortech 92 Octane tune", this is the tune that I had on the car before I had my engine rebuilt and switched over to a Diablo tuner. So that meant my tuner didn't bother to return the car to stock before he started the new tune after the build. So I thought to myself " O well, I'll just return the car to stock with the SCT and reload my new tune with the Diablo" Well I did exactly that until it came time to start the uploading of the new tune with the Diablo. I went to press select to "Install tune" and the message "Invalid tune 2, tune does not match previous tune install in car" or some thing along those lines. So I was like "****". I then reloaded the SCT tune into the car and then tried to load the Diablo tune on top of that one thinking that would put me where I started. I ended up with the same message as before when I went to press select. So now I have a SCT tuner thats unlocked and a bone stock tune in my stang. Someone help a guy that doesn't know **** about these tuners other then moding the perameters.
I assume you mean the Ford factory tune when you say stock?? If so then call up Diablo Sport and ask them if you can reload the tune into the tuner oris that message some type of failure. If it's not a major failure then all you have to do is call whoever sent you the Diablo Sport and ask them to email you your performance tune and just up load it back into it.
the only thing i can think of, is that
you need to plug the SCT back in and
select "Return to Stock".....after that
finishes, then plug in the diablo and
upload the custom tune.....
if that SCT option doesn't come up, i don't
know what to think
know what to think
Its a custom tune from JPC and I couldn't exactly get ahold of him tonight to ask him if he still had the tune.
I did return to stock with the SCT and then try to load the custom one with the Diablo, thats what I did origionally.
I'd call your tuner and just be honest with him. I'm sure he can walk you through it. There are a couple of work arounds they have. I had a problem uploading a tune on my car once and Richard called SCT. They had him do a couple of things (can't remember what they were, like turn accessory on twice for 10 seconds till this light comes on etc..) and it worked.
Sounds to me that you did it in the wrong order.
You should plug in the diablo and return the car to stock. Then plug in the SCT and return the car to stock. Then reinstall the Diablo.
The problem I think is that the Diablo is looking for the tune that was there and it is gone because the SCT has overridden it.
Basically you have to unlock both tuners then reinstall the one you want.
Thats my 2 cents.
Thats my 2 cents.
The Diablo wont let me install any kind of tune change. Every time I try to install any tune or return it to stock it give me the "Invalid Liscense 2, tune does not match last written tune" or some thing along those lines. I can install tunes and return to stock with the SCT though. Its weird.
