Any last minute words of advise for me?
#21
Location: from Warwick, RI but live in Ft Walton beach, FL
BTW i have JBA LTs with MAC O/R Prochamber
#22
Well I got the driver side header and motor mount in. That bolt on the steering rack was a hoachy mommy. Other than that the drivers side wasn't too bad, some of the header bolts are definatly harder to get at. I didn't have any problems with the starter at all. I haven't put the mid pipe on yet so I'll wait til tomorrow late morning to fire it up with open headers. Now I'm off to get a much need shower and put some ointment on my sliced up hands!! Oh... my headers ore the ceramic coated Pacesetters. They are really good quality and fit like a glove. Can't beat the price and made in the USA too!!! I got the headers and hpipe for $440 shipped... brand new!!
#26
#28
starter.. 10mm
motor mounts.. 13mm and 15mm
steering rack... 18mm
steering shaft.. 13mm
wratchet wrenches in 13mm and the size of your new headers bolts are a good idea, 13, 15, 18 mm deep well sockets, swivel, and alot of extensions and you should be good.
#29
ok, the hardest part for us was the fact that the stock manifold bolts arnt just one piece bolts like you would think, but instead looks like they thread just the threaded part in, put the manifolds in place, then a nut goes down on the threads. So when we were taking off the nuts only one of the threads came off with the nut on either side. So after hours of fustration getting the nuts off, we couldnt pull the manifolds off cause there isnt enough space to both pull them away from the block and slide them out. So now we are there with a tiny 5mm socket and a small ratchet, unthreading the headless bolts out of the block 1 to 2 clicks on the ratchet at a time.. all 14 that were left.
After all that it would have been smooth sailing for the rest of it, if not for the motor mount on the passanger side my father in law was working on. He had unbolted the mount from the block, but the block wasnt really being held up as much as we had thought, so he found it very hard to get the mount to go back on the block... So appearntly my passenger side mount has 2 1/2 bolts holding it in out of 4. I am going to have to take it to a shop that can actualy get the thing up in the air and have them put the mount back on right.
So in the end, I did get everything on but my install turned out much more labor intensive and time consuming then I thought. If I had it to do again, I would probably just pay to get it done... lol, but if I were going to do it again, i would make sure I had a better plain to get it up much higher off the ground. Knowing what I know now, I am sure if I did it again it would take half the time and have less problems, cause I now know the solutions before I get the problems.
