Removing inside door panel
Old 02-06-2009, 07:28 PM
aclass
aclass's Avatar
Default Removing inside door panel
Any of you guys in here ever removed the door panel from the inside???
My passenger door lock has quit working, it's stiff and the solenoid wont move it. Probably related to the deer damage back in the early Spring but it's strange it's just started happening. I need to get in there and see whats going on.
Thanks for any experienced input. Suppose to be 60° tomorrow so if I can keep my butt off the Harley I'm planning to tackle it.
aclass is offline
Old 02-07-2009, 03:36 AM
07musclemustang
07musclemustang's Avatar
did you look it up on the ford service manul site???
http://iihs.net/fsm/?dir=1
it should be there
07musclemustang is offline
Old 02-07-2009, 03:38 AM
07musclemustang
2 minutes and problem solved
http://iihs.net/fsm/?dir=441&viewfil...im%20Panel.pdf
Old 02-07-2009, 03:39 AM
07musclemustang
wow it actually was 2 minutes...
if you dont have this bookmarked do it now and it will be your best friend
I actually printed it ALL out and put it in binders (in fear of the site disapearing)
Old 02-07-2009, 08:33 AM
aclass
aclass's Avatar
Originally Posted by 07musclemustang
Your time is much appreciated musclemustang. Thank you
aclass is offline
Old 02-07-2009, 11:58 AM
07musclemustang
ha no worries man.. BOOKMARK THAT PAGE and that will have the answers to basically how do you do??? just about anything
Old 02-07-2009, 03:20 PM
157dB
Cut & Paste Expert
157dB's Avatar
This should help when you actually get to the dool lock fixing stage.
157dB is offline
Old 02-07-2009, 03:34 PM
aclass
aclass's Avatar
Thanks guys, all is well. Turned out to be this gooey black tar like glue that they use to stick a piece of clear plastic to the door casing. It got on my lock right where a guide was and had it in a bind.
aclass is offline
Old 02-07-2009, 08:48 PM
Johnboy7701
Johnboy7701's Avatar
Glad it was a easy fix...
Johnboy7701 is offline
Old 02-07-2009, 10:06 PM
07musclemustang
gotta love the black goo..
but it does do a good job of sealing stuff
jwog666
12-27-2021 08:09 PM
b8checker
10-08-2015 12:55 PM
Dathan
10-05-2015 05:52 AM
b8checker
09-30-2015 07:11 AM
09-25-2015 06:58 PM
Quick Reply: Removing inside door panel
