OK heres the deal, the car is an 05 manual v8. It runs fine untill Im on the highway and cruising at about 70-80 for about 15-20 mins, then the car will throw a check engine light lose some power, and it will be running pretty lean around 18 to 1 or so( I have a wideband 02 sensor). It does this for about 5-10 sec and then the symptoms go away and the engine runs fine. I have the xcalibrator so I can check DTCs, but the ECM doesn't store any codes nor will it read any when the actual CEL is flashing. Please help, I am a marine mechanic so I know my way around engines but I cant figure out where to start with this one.
ok thanks guys it seems i gotta look into the fuel pump issue what do you think the best option would be since I do run nitrous sometimes should I just go with the GT500 pump?
