..HELP!!!!THRottle bodyand or mafs
with the headers. there are many cam options. look at the hot rods or comps. for my car im grabbin the stage 2 spr from comp. little pricey since they require springs and a phaser limiter but damn they sound so good. look on youtube to see what sound you like better.
yea an AL driveshaft def, check jegs, summit, partshopper. An alphabet cam would help you out, for what u have now anyway, not sure what your plans are but if ur staying in this neighborhood a ford racing cam such as B,E would be ideal. maybe a short shifter, shortens throws obviously and makes the car a lil funner to drive. The TB and MAF combo is a good idea, cheap for the most part and together wont give u much but every bit help. Set of good tires also will help out
dear god dont listen to 03 cobra,
alot has changed since 03 and our maf is good up to about 700 hp and the tb up to about 400 RWHP that is
there arnt alphabet cams but two majors are ford racing performance parts hot rods (non alphabet enough?) and comp cams varieties.
there are others but i dont know much about them
jwog666
12-27-2021 08:09 PM
