Paxton or Vortech for dummies like myself
#31
Mudflap, see my sig? I think I've put quite a bit of thought into my set up. The cooler the air, the better, both for horsepower and the likelihood of premature detonation (which is what breaks rods and pistons). Just because you have a kit that will make over 450 rwhp doesn't mean you actually have to. It's pretty simple: tune it to whatever power level you want. But at the same time, it's better and safer to run cooler air.
At 8 lbs of boost, an intercooler just isn't a required piece of hardware. This is even further the case with a centrifugal blower where boost is progressive, because that 8lbs is peak boost at peak RPM. On a hot day with a proper tune, timing will be reduced due to the high intake temp resulting in less power, and ultimately helping to protect the motor. This happens to a lesser degree on an intercooled setup, but its not immune. I've said it many times before, an intercooler is never a BAD idea. I wouldn't talk anyone out of it, however I would also say to anyone looking to go FI to do your research. These kits cost THOUSANDS of dollars. I'm just trying to urge anyone looking at one to consider all options and find the right setup for themselves.
09-16-2015 07:53 PM
ernesto-619
09-10-2015 01:32 AM
Soldier GT
08-12-2015 03:46 PM
