what block to use in a build?
I am looking to build my stock 4.6 3v I have a 2.3 whipple HO. I am going with all forged internals,cam,ported heads ,arp bolts and more. I also want to bore and stroke the motor to a 5.0. Should I use my cast iron block which is a four bolt main or look for a 2004 cast iron cobra block which is a six bolt main? I want to end up with 650 rwhp. Thanks for your thoughts.
i am also looking into using a terminator block for my build, but havent quite decided yet. i can get one for $600-700 locally so i want it bc it's cheap. i email'd Sean Hyland and he said i would need to get 3v pistons or the exhaust valves will hit the terminator pistons. you would also need some motor mount adapters. there is a guy that uses a MMR block built for a 4v, but he is using his stock 3v heads and cams and it is working.
here is my thread on the terminator block
http://s197forum.com/forum/showthread.php?t=12806
and here is the other thread that uses the MMR block
http://www.modularfords.com/forums/s...d.php?t=100146
and heres the engine mounts for a terminator block
http://www.seanhylandmotorsport.com/..._engines.shtml
NOooooooooo, the block on a 2005+ Mustang is aluminum. The money for a 5.0L is a waste very minimal gains. The best foundation is M-6009-A463SC FRPP 3v aluminum short block, I'ld go with FRPP CNC ported heads too, as for cams make some phone calls to find the best ones suited for your Supercharger.
