3.73Gears broke transmission? WTF?
#22
He opened her up again and checked everything.
Says he did everything accordingly.
Someone suggested it might be due to lack of "Anti Friction Additive" in the Differential oil.
So i got the ford recommended Motorcraft oil and additive. He put it in today. Still had the same noise as i drove my car home.
Does anyone have any other suggestions?
Is there an ford tech business/institute or something, that can talk him through the install?
Again, the sound it like a dull whine. like something keeps spinning on when i let go of the gas or brake. as i come to a complete stop there's minor "clicking" along with the other noise.
It's enough to drive a man insane.
BTW - My car is an automatic.
#24
Sorry this may have already been stated but I didn't feel like reading through the whole thread, I had a '99 F-150 making a very similar noise to the one your describing, took it to a shop they said it's the rear-end making a-liitle noise no biggy normal after awhile they said, after about 2 months the noise was loud it would give yyou a head ache, anyways the pinion bearing was making the noise due to something not being lined up right or angled wrong. Well the slight misalignment was enough to warp the pinion bearing and the housing it sits in. after paying 1200 bucks for a used rear end all was well
#25
i went down this road with some assclown shop in town, they f**cked up the install and the differential got ruined, I had to get a replacement, they paid for new gears but not the differential, be AWARE, go to shops that have installed gears on these cars !!!
#26
still driving me crazy. if the gearing noise wasnt enough, my brakes started making noise also (mainly because it's very wet outside, the rotors are probably"cracked" or whatever you call it..)
Dont stop with the suggestions...
#28
Alright, was just hoping, it might be something that hasnt been mentioned yet.
My mechanic opened her up again and says he's sure he did everything "by the book".
He's one of the few mechanics i trust, so i'm feeling pretty hopeless about the situation.
I'm going to contact brenspeed and ask if they have any helpful tips etc.
Worst case scenario, something 'll break; like the diff. or i might have to replace the whole rear axle.. in which case i've seen them sell with the 3.73gears as well..
#29
A great example of why I won't let non-Ford mechanics touch my Mustang! Especially if it's under warranty, as your 2007 should still be! If they screwed up the gear install and something broke it would be covered.
Since an outside shop modified your rear gears, anything that happens with your driveshaft might not be covered!
There are a ton of posts on this forum about gear install problems and dangers...
#30
Think about it, gear swaps are not routine mechanical requests or warranty items. Many of the Ford techs have probably never done one even though the work on Fords. It's takes practice, skill, patience, and the right tools to get a gear swap done correctly.
It's threads like these that have kept me from doing a gear swap in my current Mustang. There are too many starving mechanics in this economy that claim they know how to do these just to get your business.
