motor mount install question
Is it possible to change out the motor mounts without removing the motor mount brackets? Because that passenger side bracket is a serious #*$%^& to get in and out of there.
I know I can jack the motor up to within about 1/4 inch of the brackets clearing the motor mount bolts. I wonder if when I unscrew the mount itself (not the brackets) - would I be able to wiggle the mounts out of there and then wiggle new mounts back in?
Hope that made sense.
The prothene mounts are actually shorter than the stock mounts & installing them should not be an issue, but removing the stock hydro mounts is another issue, as they are actually recessed into the frame rails & will require you either jacking up the motor quite a bit or onbolting the mount brackets to remove.
Installing the prothenes is a piece of cake compared to removing the hydro mounts.
