NITROUS QUESTION (please come in)
for the people using a 100 shot need some info.
1st- what brand kit are you using
2nd- what jets are you using n2o/fuel
3rd- what are you using to boost the fuel if your using any
4th- if you have dyno what are your numbers hp/tq
thank you
thank you
i have a zex kit with all the fixin's...window switch, purge, bottle opener, etc. if you go to zex's website, there is a link that will give you a chart of what jets to use for whatever HP you want to accomplish. you can use a handheld tuner to make your car run a little richer but the best way to accomplish this is to get a dyno tune.
1. Dynotunenitrous wet kit.
2. The jets that came with the kit to equal the 100 shot. I'll give you the exact size when I get home.
3. Nothing to boost fuel. The stock fuel pump and injectors are fine.
4. I'll post my crap dyno sheet later. I had a major exhaust leak so my hp and torque numbers were low. It was also a cold day and didnt have a bottle warmer. Need to go back.
I know I have a 2000 gt but it can be a good foundation to see what you would have at an utmost minimum. Your car will make way more power and at a minimum it still would produce better numbers than mine. Your minimum > my minimum
