problem with fuel pump
i have a mustang 2007 with prochargerstage 2 10 psi , the problem came many time and i fixed many time but i dont know whats i do
the problem with the ( FUESE ) for the fuel pump ( GT500 fuel pump ) and the fuse for BOOST-A-PUMP , when i wot the fuel to high rpm like in 6000 rpm the one of those fuse will barning and the car all most stop , i change it many time , and i use 20 watt fuses
waht shoul i do
thanks
waht shoul i do
thanks
Which BAP do you have? The SINGLE or DAUL?
http://www.kennebell.net/accessories...boostapump.htm
I know that the Single requires a 30A fuse on the BAP and a 30A fuse in the car.
I am not sure about the Dual. Contact Kenne Bell they will let you know what is going on.
