Help! Lost bolt from shifter
I installed an MGW shifter about 2 years ago on my 2007 GT. It is a great shifter, but today while driving, the 10mm bolt that holds the shifter support to the transmission came loose and was lost!
Does anyone know the part # and where I could get a replacement? If not that, could some one tell me the thread size and pitch so I could find something at a hardware store?
Thanks a ton!
Thanks a ton!
Not sure, did you try the dealer? I think that bolt is a OE bolt, not one that came with the shifter.
I need to check mine, I've had mine since they came out and never checked anything, and lately I seem to get locked out of a gear now and then. 4th gear no less, wtf!
Hmmm 10 mm bolt.
It has 10mm threads with a fine pitch?
http://iihs.net/fsm/?dir=290&viewfile=Gearshift Lever and Boot.pdf
Item #4?
It does not seem to have a part # associated with it...
But it seems to be a shoulder style bolt and not a common
hardware store item.
Blue LocTite 242 that puppy next time.
Item #4?
junior04
09-28-2015 10:53 AM
