Engine revs after taking foot off gas pedal...
This hasn't happened very often (about three times in the last two months or so), but sometimes after I accelerate away from a stop and then lift off the gas, the engine will momentarily rev a little higher, even though I've lifted my foot off the gas. The car drives perfectly fine other than that. Anyone know what might be causing this?
it could indeed be a dirty/sticking TB. if it continues after cleaning, i would look into replacing the TPS sensor.
i had some odd throttle behavior that was fixed by replacing this. takes 20 min and $70
I had this problem a few years back shortly after installing my JLT-II. It didn't happen all the time and wasn't bad enough to warrant fixing it at the time. I then installed a Bama tune and started getting a severe lope at idle - I cleaned my throttle body and MAF and never had either problem again.
I bought my 07 used with 14k miles and it does it more often than not. I thought is was me. Everything is stock as far as I know and it seems to do it more when it's colder out. The other thing I noticed is a slight hesitation in accelaration when first starting it after it has sat awhile. It still has the orginal filter which looks pretty clean.
Scott
I get that often when i shift quick. I thought it was a lag in throttle/fuel injection resulting in a little more combustion when i press in the clutch. I guess i will have to check my TB. But the front of my tb looks clean.
I had idleing problems, as well as what the op mentioned. Cleaned all the electronic connectors to the TB/intake and the MAF sensor, and everything was fine.
ShaneB26154
35
03-04-2021 04:05 AM
