Weird Electical Issue
Just as I was about to hop in my car I noticed both key fobs stopped working, so I opened the door manually. Once started the DIC read low oil, low coolant and an error code of some sort. The power windows, power locks and headlights no longer turn on/work. Is this a common problem? Any ideas?
Thanks
Are these cars OBD2 or 3?
Thanks
S197
Change the sig.
You are confusing us.
https://mustangforums.com/forum/4-6l...oder-list.html
Well after removing the doorsill and kick panel I had a friend hose down the roof ditch moldings, side window weather strips, and windshield/cowl panel area. I must have spent a good twenty minutes looking for a water leak but I couldn’t find a single drop! What gives? Is the sjb the main cause of these electrical problems most of the time? Should I try pressurizing the vehicle?
Thanks
Thanks
Thanks
Thanks
The SJB controls almost everything electrical except the window motors,
the Climate Control, the passive restraints, the PCM of course and
a few other things. If it gets wet and there is power on it, its soon toast
from galvanic corrosion.
The rear vents can be taped and the fresh air inlet open, highest
blower along with a squirt bottle of soapy water and the leaks will
appear like magic. I was in the car wash with the blower on high
and found mine by accident... Black plastic door/window trim passengers
side above the rear view mirror where the foam sealing strip had become
dislodged.
PM me with an eMail addy and I can send you the two TSB PDFs.
Well to make a long story short I gave it another shot today and came out with a leak! The leak from what I can see is coming from one of the two seams above the junction box. The top seam is leaking water every time I run water over top of the windshield shroud. It’s almost as if the weld that holds the two panels together underneath the shroud was poorly done. I’m not sure how I did this but at one point when I soaked the seam/shroud the water entered the car like a running tap, but I was unable to duplicate it. If my problem is the joint weld, what would be the best way to go about fixing it? I looked for the two vents in the trunk but couldn’t find them. Where exactly are they located?what do they look like? and how effective is the soap and water technique?
lincolnshibuya
12-08-2015 04:37 PM
mungodrums
09-28-2015 10:54 PM
