Timing chain noise
Timing chain noise
Hello all, just wondering if anyone here has encountered the same problem as me. When i start my car on early mornings, the timing chain makes a slight grinding noise. It only makes this noise occasionaly, however. I believe the noise is because the tensioner inside the timing chain cover has blockage and doesn't get oil pressure on initial start up. The car makes the sound for only about .5 seconds, and it runs fine without any problems. I just drove it out to Lake Havasu in 120 degree heat for about 600 miles with no problems. If anyone can be of any help, it would be greatly appreciated.
i haven't seen other reports of this. i see why you may
be concerned....i've read about how on some
fresh engine builds, if the tensioners aren't primed
manually, or if the engine is started and the
tensioners don't prime up quick enough, that one
of the timing chains could jump a tooth. it's hard
to imagine how this can happen, but never the less
it has been reported on other boards.
what is the fix? not sure, maybe going to another
oil rating. changing the tensioners would be an
annoying weekend project, that's for sure.
thanks hammeron... no kiding it is a PITA on this car to get to the timing chain. Like i said, the car seems to be running fine but next time i change my oil, maybe i'll change the weight. It has 5w20 in it, what do you think i should swithch to?
on muscle car TV on Spike TV they recommend that you take your timing belt off and wash it from time to time and scrub all of the gunk and corrosion and dirt and what not off of it. I think you should also lube it up before you put it on. Not sure if timing chains work the same though.
mungodrums
10-07-2015 04:01 AM
