Can i read How many lb's of boost i running from a vaccum gauge
x2...
sounds like you are tapped into the vacuum supply for the boost bypass. anywhere else will give you either full vacuum or full boost readings. My RoushCharger bypass had several vacuum lines running to it, so i can easily see someone plugging into the wrong area.
there was only the 1 vacuum/boost line on the back of the manifold that I actually needed.
Thanks for all the help guys, i have just tried moving the vaccum line. i moved it to the side of the s/c on top of the injector rail. it goes up in to something like 8 psi, does the car have to be moving to show true boost figures???
Thanks
Thanks
But just reving it parked will not give you true readings.
YoungStangsMan
09-05-2015 07:01 PM
