07-08 mustang gt and v6 tranny same?
Old 12-16-2009, 01:40 PM
07ssixer
07ssixer's Avatar
Question 07-08 mustang gt and v6 tranny same?
I found a v8 out of a 2008 mustang gt and i was just wondering if the tranny in the gts and the v6s are the same? theyre both auto tremec 5 so would my tranny work or not?
07ssixer is offline
Old 12-17-2009, 12:09 PM
2007VistaBlueGT
2007VistaBlueGT's Avatar
Different bolt pattern, the V8's use a bellhousing bolt pattern for the modular motors, the 4.0L V-6 I believe uses the Windsor bellhousing pattern.
2007VistaBlueGT is offline
Old 12-17-2009, 12:18 PM
rdsx18
rdsx18's Avatar
They are not the same, IIRC the v6 has a T-5 and the GT has a T-3650. The T-5 might bolt up to the GT motor, but I have no idea, you'd have to research that.
rdsx18 is offline
Old 12-17-2009, 01:09 PM
cavediver
cavediver's Avatar
Even if you get a V8 transmission you'll still need a GT exhaust. wiring harness, Powertrain Control Module (PCM), engine mounts, front brakes, drive shaft, rear axel assembly including diferential, front and rear sway bars, springs, and the list goes on and on and .................................the $$$$$$$ go on and on too.
If you want a GT, buy a GT. Much cheaper and easier.
cavediver is offline
Old 12-19-2009, 05:03 PM
07ssixer
07ssixer's Avatar
Think Im gonna just charge the sixer lol sounds like too much **** to go through. only get 350..ish hp but its alright for a v6. thanks for your input guys
07ssixer is offline
ShaneB26154
35
03-04-2021 04:05 AM
treesloth
09-28-2015 07:03 AM
2poor4u2
09-26-2015 11:08 AM
prophotog
09-15-2015 08:38 AM
jaiidutch
09-14-2015 10:29 AM
Quick Reply: 07-08 mustang gt and v6 tranny same?
