installed aluminum driveshaft
#21
Yep going with the Adapter Plate version, so 499 Shaftmasters I'll give a shot. I've heard no bad about them, and if not racing, I don't hover above 80 for any time period anyways, if I'm in South Dakota on 94 it's 75 on freeway, then we'll see.
#22
I think that an aluminum drive shaft sounds like a great mod. Glad to hear you guys are really enjoying it/noticing the difference. Saving weight in the driveline should mean more RWHP right? Less rotational weight in the system means less loss from flywheel to tires? I would think the pick up would be a bit snappier and the fact that braking seems to get better is interesting too.
How much weight do you save upgrading from stock?
#23
I did the shaftermasters with the adapter. It is smooth as silk. I have been to 130 with it and not a virbation anywhere. The response is better, the car is much snappier out of the hole and it has better freeway pickup as well.
The isntall (on a hoist) took me about 1 hour. Very easy. If I had to do it in a driveway, it would have been 2 hours just because of the added time to crawl around. In anycase, it is an easy and basic install.
I wouldnt hesitate doing it for a second.
#27
Yeah, I'd do this myself if I had a lift but I hate crawling around under a car on jackstands so if I do this mod, I'm paying somebody.
Say DEW, how 'bout some pictures of the electric front plate holder? In both up and down positions if you don't mind. TIA.
#28
This install really isn't that bad on jackstands, nothing like headers. But you have to put the car in gear and set the parking brake to keep the driveshaft from turning while loosening and tightening bolts. You have to rotate the shaft a couple of times to get all the bolts which requires some back and forth from under the car to in the car, but overall it only took maybe 1 hour. The only part that is slightly tough is getting the stock shaft out and moving it around once unbolted as it weighs so much. If that thing fell on you, you'd be a goner.
#30
Oh I agree, but I guess it's a phobia about the jackstands. I love to do my own work as I'm able. Know what you mean about the wife too. Mine sort of freaked out when she saw the whole rear of the car disassembled when I put the Roush valance on.
The SSS axlebacks are coming today so hopefully I'll get to them this long weekend, if not tonight.
