Forged Rotating Assembly
I have a 2008 Mustang GT and I'm considering the Edelbrock supercharger from Brenspeed that puts out 520 HP at the crank.
Now I'm gonna go out on a limb and say that at least one or two of you would recommend getting my rotating assembly changed out with forged if I want that kind of power.
My question is, assuming I already have the parts, how much money are we talking here in terms of labor to have this done? I'm perfectly aware that this would vary quite a bit by region and shop to shop. So just give me a general ballpark. Will it be under or over $2000?
Thanks.
Thanks.
Okay so I just got done reading another thread and I'm under the impression that doing anything major to the stock engine may not be the best idea for reliability reasons.
So lets say I want 500 HP. I'm assuming that'll be under 450 at the wheels. Am I correct? And what SC system would you guys recommend for that kind of power that doesn't run me the risk of my motor going kablooey? (twin screw or roots type is prefereable)
You can still get the e-force blower and use it on the stock block. Many people have done that with great results. Just keep the power around 450 or less at the wheels and get a GOOD tune and you should be fine.
This car being my DD, I need a kit from a company who knows best.
Welp...I had my stock block turned into a 302 stroker and with all the other things that I ended up doing along with it, converted trans input shaft to 26 spline, spec 3+ clutch, got a SCT X3 tuner, stainless valves, new guides drainback valves, windage tray & modified oil pickup and other things that all have to happen it came to nearly $13k when I was only expecting 6-7k in the beginning.
I know my engine and trans are ready for some good boost after I get the work paid off but it just means I have to wait longer than expected. I just wanted to build the motor first rather than boost it, pop it, then build it.
Plenty of people are boosted on their stock blocks with no issues, just be sure you go to a reliable tuner that won't try to just get you as much power as possible and not keep your engine alive.
