C&L filter replacement
I have a C&L Racer intake and the filter was touching the metal part underneeth it and it got burn a little bit. I want to replace it. Would any filter like this would do:
http://shop.advanceautoparts.com/web...%7CGRP2026____
or would it be recomended to get the same one from C&L ??????????
I don't see why you couldn't use another filter. As long as the diameter is correct where it connects to the tube, why not? The cone style filter that comes from C&L looks just like a K&N anyway. I'd be willing to bet that it flows similarly also
There are a few choices for replacement conical filters. Amsoil sells a dry filter that I consider to be a decent replacement. I had googled this issue about a year back and if I recall, there are a few different filters, both dry and oiled, to choose from that will work fine.
I had a rub on mine,
just loosen the mounting screws and raise the end of the intake a bit to prevent any rubbing.
even with the larger filter I have no rub.
A friend of mine just added a thick rubber O-ring to fix his rub, but I like repositioning the intake better myself.
and no more oily mess.
that is part # EAAU4090
http://www.amsoil.com/catalog.aspx?c...-EA&zo=1667299
EaAU4090
replaces k&n #RE-0870
EaAU4090
That's a nice looking air filter ShadyNinja. Definately an under-hood, "Wow", modification!
How much was it? Does it filter and flow better than the old school oil wetted K&N? I've heard they do.
