cam picture?
cam picture?
does anybody have a picture of the passengers side cam bolting into the phaser? stock or aftermarket cam pictures.
i need to know if there is a little space it looks like where the cam bolts into the phaser on the back of the phaser.
it doesnt looks perfectly flush to me but i dont know if its supposed to look like that or not.
thanks!!!
thanks!!!
i think you are probably ok. the alignment
keyway only allows the cam to slide into
the phaser one way and the cam only
slides in so far.
as long as the phaser is on the cam, the
keyway is lined up and you get the bolt
in and torqued, all should be good.
slides in so far.
hmmm. yea its all torqued but man it just worries me lol
i dont want to screw up a motor cause of it and im about to go to ford so i might order another bolt just in case
but i picture would def def help just so i feel reassured
heres a picture i took tonight of the FRPP Hot Rod Cam. now what confuses me is the lobes on the camshaft lines up with the lifters and the chain on the phaser is directly in the middle of the orange tensionor that is in the timing chain cover area itself. so it seems everything is lined up perfect BUT this just looks very very odd
daltron
04-28-2016 08:10 PM
junior04
09-28-2015 10:53 AM
