You will prpbably need:
heat exchanger= 300 (AFC))
Bosch IC pump=100
IC hoses=40
coolant=20
BAP=200(?)
injectors=300(?)
belt=30
You can make the CAI froma 4" carbon or fibergalss tube and some clamps and rubber sleaves. (100?)
Vacuum lines
Bracket for the PCM
wires and connectors
There's tons of little stuff. If you got a set of directions from KB on the install it would give you pointers on what you would need.
Not trying to be a jerk, but this is not a project for a college kid on a budget. Still, I hope it works out for you.
I understand for sure. The only reason I'm even attempting is because of the people I know, **** the mustang factory is 2 blocks away from my house. I met a lot of connections helping on the set of Motor City Motors this past summer as well.
