2010 exhaust sizes
2010 exhaust sizes
Hey guys I need some 2010 specific info if anyone has it. I have read the exhaust on the 2010 is 2.5" and pre 2010 was 2.25"? (assuming this is OD?)
here is what i bought.
X-Pipe from rock auto. 2.5"
1 mid pipe from rock auto 2.5"
what i want to do is cut to y-pipe off at both pipes coming down from the cats. slide the x pipe in, clamp with band clamps.
slide both mids (1 new 1 stock) in the x and band clamp.
my ? is the x i got has a tapered end to insert into the pipes coming from the cats. are the pipes from the cats 2.5" OD? if so i have no problems, if they are not it wont slide in right?
the x pipe has expanded ends for the mids so the mids can slip right in so i can clamp, which is good on the "new" side. the stock mid @ the y has a stock band clamp, I might have to cut that off.
does this make sense? i just want to make sure this x will fit with my stock cat pipes.
http://www.dynomax.com/assets/instru...structions.pdf
did my conversion over the weekend. the pipes coming out of the engine after the cats are 2.25"
the stock midpipe is 2.5.
the x pipe o bought fits right over top the pipes coming from the engine. the mids slip right in the x.
clamped it with band clamps and and it welded today for $25.
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
11-09-2016 11:44 AM
NorthAmericanTuning
03-18-2016 11:21 AM
mustangsrforever!!!
08-06-2015 12:04 PM
