Which valve covers ?
So as April rolls ever closer, and with it, the remote chance that I can get the car rolling (even though the reality of salt free roads is probably closer to May), I'm doing some upgrades and other bits to the car.
I was considering painting the valve covers bit also mulling over picking up a set of power coated FRPP covers.
So, to the question.
I remember talk before of the valve covers changing during 06 or 07 from an 8or9 bolt pattern to a 9or10 bolt.
My car is in a position where it's impossible to check the pattern on mine right now, but regardless, does that matter even? Are they interchangeable as I also vaguely remember someone saying?
I'm leaning toward just buying them coated but don't want to end up with another wasted exercise in futility.
Thanks Boys
Marcus
Thanks Boys
Marcus
EDIT........thanks for the bigger pic!
Interesting. So I'm guessing the extra bolt lugs just remain redundant, or are there holes in the heads for those extra bolts to drive in to?
Also, does the new Cam sensor hole require a different cam sensor or just a different grommet?
The cam sensor/solenoid is the same just a different grommet in the cover.
