Squeacking after suspension install.
I installed FRPP lowering springs, FRPP shocks, FRPP anti sway bar, BMR lower control arms, BMR adjustable Trac bar, and BMR Lower control arm relocation brackets. Now everytime I go over a speed bump or pull into my driveway I hear the rear end squeak, i've removed the springs and put them back in with no change in sound. Has anyone had this problem, or by chance know how to fix this? Any idea would be helpful.
it probly you lower controls did you torque the bolt properly to specs?if so did you lift the rear end off the ground to torque them if you didnt thats probly your proble also make sur the bushings are well oiled...
Lube the bushings and tighten up all bolts at ride height.
Torqued with the wheels hanging will put the OEM bushings
in quite a bind at ride height and cause squeeking when
they rapidly deteriorate from over flexing.
Lube,Lube,Lube evvyting.
Matt's 95 Stang
10-05-2015 07:16 AM
