Looking for advice for a procharger install
Ok, I've finally got some funds and can put this baby in. I need a few things first. I need fuel injectors, spark plugs and a boost-a-pump. Is there anything else I'm missing? Also, what's a good place to buy this stuff at? I found stage3motorsports.com but I'm looking for opinions. Also, if you have done this install, please let me know of anything as far as tips go.
Another question I have for current PC users, what is that hose that is black, kinda like rubber and it has metal rings in it? I think its the coolant hose, but not sure. Basically, I have a hole in mine and need a replacement. So, I wanna know what I need to google to get it. Thank you in advance.
That hose is for the bypass. Go with 60 lb injectors if you want to make big power some day. Make sure you get the 40A boost a pump as well. Don't be scared to trim the rubber 90s that go to and from the intercooler either. It will be a tight fit. If your using a used kit make sure the bypass valve is in good working order. If you ever hear a fluttering sound at idle you know the valve is stuck shut. I never drove my car much so mine was stuck often. I had a P1 on mine and loved it. For future reference, don't go any smaller than a 3.2 pulley on a 6 rib setup or you'll start fighting belt slipping problems.
