Lost 5th and reverse
I bought an '08 GT premium that has a Steeda short throw shifter installed. I've had it for 6 months and had some issues with 2nd but it's there if you look for it. Now all of a sudden I lost reverse. 5 minutes later I lost 5th. So now I have 4 gears. I assume it has something to do with the gates on the shifter. Anyone ever had this problem. How do I fix it. Does the installation of a short throw shifter invalidate the warranty?
Thanks for any help you can provide. |
My buddy lost a couple of gears with the same shifter at the track and all it was were loose bolts that came off and clogged the gear changer(stick). Not sure if this helps, hope so. Inside the boot of coarse. Good luck
Originally Posted by Snakebite64
(Post 6938268)
Problem identified
(Post 6938268)
