Help wit Vortech SUPERCHARGER!
Hey guys i just recently bought a used supercharger . Vortech V2.
He sent me the link of when it was buoght and its for a 2007-09 whats the difference in putting into my car since i have an 06.
Also its a tuner kit. So what should i get for good engine and fuel management ?
Thanks alot guys just looking for some help..
most likely you'll need a set of injectors and either the GT500 dual fuel pumps or a boost-a-pump for your stock pump. you'll also need a big enough MAF for the power your running.
just as an example my Kenne Bell kit come with 39 pound injectors, a 90mm MAF, and the boost a pump for the stock pump. that's enough fuel for around 550whp. I'm running their tune from their kit.
you'll need a tune so I'd work with whoever you're getting the tune from as to what to get. but budget for the MAF, injectors, and either the BAP or GT500 pumps.
If I was you, I would hit up a shop/dyno/tuner that deals specifically with mustangs. Be safe.
I'm telling ya, where you get your tune is going to make you or break you.
Definatley your gonna need injectors and a boost a pump. If not you are gonna run out of fuel way to early and you wont see any significant power gains and some thing will eventually fail on you. So you might as well get them now and be safe.
412whp isn't that hard on boost, don't go cheap on the fuel system! (or tuning)
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
