new rims new gears...helppp
Your current gears are what 3.55? 3.73 wont do much at all. 4.10 for sure. Do a search of 4.10 gears and read what others have said about them. I have them and love em. I have an auto trans though.
patrick
patrick
http://www.miata.net/garage/tirecalcold.html
Put in your old rear tire size before the 19" rims
and put in your new rear tire size.
Rims dont make you go slower (unless they are made of lead),
its the rolling diameter of the tire.
What did you have on there before the swap that you are
comparing the new tires/rims to?
Define 'alot slower'...
Help us with detailed info and detailed responses will come forth
bump
bump
i had stock rims. You might be right about the rim wieght i never checked how much it was. By slower i mean that my 0-60 now is nothing what it used to be when i had the stocks on.
these are the rims i bought. do i just need new tires im lost with this crap i honestly dont know alot about this so your anwsers help out alot.
http://cgi.ebay.com/ebaymotors/19-In...5fAccessories\
thanks alot
thanks alot
What you loose in 0-60 times increases your top speed.
Loose top speed and 0-60 becomes better.
Looks like the tires are bigger round and its
killing your low end torque.
Gears will help that.
Dont go too steep or you will loose top end again.
Its a big ol balancing act and you upset the teeter
totter when you got heavier rims and taller tires.
Do you want looks or performance.
Its a fine line to have both....
And costs $$...
And costs $$...
