08 GT Creaking Front End
They do a check to confirm the noise source is your lower control arms and if it is they replace them with new ones that have an improved hydro-bushing and a larger diameter ball joint shaft.
More details here:
http://www.stangmafia.com/forum/f122...trol-arm-6588/
More details here:
More details here:
More details here:
Do you have the stock suspension? I have heard all the following can be contributors to front end noise:
1. Front Lower Control Arms - TSB 09-24-16.
2. Upper strut mounts - TSB 07-18-02.
3. Sway bar end links being loose.
4. Upper Strut retaining nut loose.
