Does that stuff work? I had a friend show me using the Vl method and all that I saw was a large amount of smoke. I know some people swear by it however.
It is a cleaner and decarbonizer works great, fuel injected or not, if you are having any pinging with a high octane tune and the gas you are using is good quality, this will usually fix the issue. Use this method before a plug change, helps to loosen carbon on the dreaded 2 pc plugs
Since the 3 valve engines have no real pcv valve, just a valve cover baffle, you would be surprised how much oil makes its way thru to the cylinders, which leads to carbon buildup. A catch can/ oil seperator solves this problem
This is the hose i used to get the SF in. I put my finger in the hose and it came out covered in oil. First chance i get i'm getting a separator.
