Mustang GT 4.6 Problems.
A greeting from Spain.
Mustang starts up , then i get going and say i'm cruising in 1st and i let off the gas; instead of slowing down like it normally would, it keeps going at that rpm. then say i'm cruising in 3rd at 3000 rpm and i push in the clutch, the rpms stay at 3000 for a few seconds. sometimes up to 20 seconds then they start to slowly fall back down to 1000 or so. it does this in every gear. Everything begins after cleaning the Throttle. Anybody know ? Thanks.
Maintaining the high RPM's aid in burning any remaining gases in the combustion chamber from what I'm told and may have other Ford-determined benefits. I couldn't say.
Yea, but he's saying the RPMs hold up there for a long time, like "up to 20 seconds." If that began after cleaning the throttle (body), there has to be something sticking or a bad TPS, wouldn't you think?
Well, if this problem didn't start until you put the new throttle body on, it is logical to assume something there is amiss. Did you try disconnecting the battery for 30 minutes to reset the computer and force it to "relearn" with the new throttle body?
NorthAmericanTuning
03-18-2016 11:21 AM
KEM Motorworks
08-14-2015 10:13 PM
