extreme power loss with A/C
Old 05-27-2010, 06:53 PM
redstripe
redstripe's Avatar
Default extreme power loss with A/C
OK here go's today was the first day i actually used my a/c this season. when i accelorate it feels really flat like im driving my girlfriends civic. has anyone else had this issue ? currently i just have a sss axle back system jlt intake an sct tunner can tunned. Any insite would be good thanks.
redstripe is offline
Old 05-27-2010, 07:13 PM
socalwrench
socalwrench's Avatar
The A/C compressor does take up a decent about of power, and it can be felt even on a V8. It's been one of my peevs with Ford for a long time- they use an a/c system that simply cycles the compressor on and off; it's not variable. You will notice when the compressor kicks on.
You can either manually turn it off, if you need full power, or simply floor it. The PCM will switch off the compressor at WOT. Although, it still shouldn't feel like a Civic - lol. You might really offend someone with that comparision.
socalwrench is offline
Old 05-28-2010, 09:56 AM
StickShifty
StickShifty's Avatar
my car does loose a nice chunk of power with the AC on. it will still get up and go.
StickShifty is offline
Old 05-28-2010, 09:59 AM
Alec
Alec's Avatar
Time for underdrive pullies?
Alec is offline
Old 05-28-2010, 10:09 AM
Nuke
Nuke's Avatar
I've never owned a car (have owned at least 9 or 10) that didn't feel like it had the life sucked out of it with the A/C on. Considering the load an AC compressor adds to an engine, are you really surprised?
Nuke is offline
Old 05-28-2010, 10:23 AM
157dB
Cut & Paste Expert
157dB's Avatar
The S197 cuts out the AC at WOT BTW.
I was going to add the mod but a little
detective work proved Ford designed it
that way already....
157dB is offline
Old 05-29-2010, 01:07 AM
gman73
gman73's Avatar
Maybe the underdrive pullies help, but I don't notice too much of drop of power when the A/C is on.
gman73 is offline
Old 05-29-2010, 09:04 AM
157dB
Cut & Paste Expert
157dB's Avatar
The AC cycles and UDPs dont effect it that much.
The compressor cycles just become longer and
shorter inbetween but it never runs 100% indicating
a loss of cooling power. If it compresses the freon and
then there is enough excess compressed freon, the compressor
cycles off. This indicates that the compressor is keeping up
with the compressed freon demand for any one cooling situation.
157dB is offline
jwog666
12-27-2021 08:09 PM
baddog671
07-26-2016 01:20 PM
jrrhd73must
10-02-2015 09:17 PM
09-25-2015 06:58 PM
Quick Reply: extreme power loss with A/C
