I know where I screwed up the firmware I downloaded is for the tuners that start with xp in the serial number. but the next 5 digits must be lower than 010809 which means that it had to be made before jan 1st of 2009 and mine is 081309 which means aug 18th 2009
i'm starting to think it was a bad download.....looking at
the SCT notes it looks like you did pick the right version
even if the date is wrong it seems like it should still work.
i would download it again and try updating once more.
I have been in computer for 25 years and this is a perfect example of why you DON'T do updates unless you NEED to. Never update unless it 100% has to be.
i couldnt get the tunes from bama to download into my tuner and the directions said i need to update the firmware
i finally got it to work it was a bad download i downloaded it again and it works and i got all my tunes downloaded to it as well thanks for all the help hammeron
